What's this?
Hi all
Sorry for the newbie posts but while cleaning and generally checking my car out today I spotted this
8829d117658c7c19bc589b667a85b7ef_zpsrosk
I assume it's a breather or something similar, I've made a temp fix but can anybody shed some light on what it's called so I can buy a new one?
Devonutopia is selling one of these give him a shout.
Will the split make a lot of difference?
Yes I believe it does I have a TDI so not certain.
That's the y-piece breather hose. Common for splitting. Can cause hesitation and generally running rough
Yeah replace it, engine won't run correctly with it like that. Chances are some of the Vacuum/boost pipes will have splits too. S pipe under the inlet manifold is notorious for splitting.
Edited by pauldazzle
or just catch can it get rid of the pipe that way
I replaced it and the s pipe and now I get random hesitation when accelerating mainly in third.
Could it be MAF? No other symptoms, Rickover and general driving is fine
Do you have a VagCom? If you do try some logs and fault code readings,maybe the scanning will have something to say...
Edited by ThomasItis
