Cables into BCM
Your probably all fed up of the saga. BUT.
Ive run the trailer wiring through to the glove box.
Ive got the BCM plugs out (very tight fit) and removed the relevant wires, put in the extra cabling.
Now I have to reinsert wires into the BCM plug, but its very fragile and not obvious how it connects.
Any help anyone?#
Please?
If it is anything like the CAN Gateway connector it is in two pieces, one piece locks the pins in place. If that is removed they should just slot in, making sure you have the little tab on the pins on the correct side so they engage in to place?
Does this help
I think at 07:27 we have a winner. But in reverse of course!
Thanks Andy. I'd started watching that clip but had to run little ones bath and missed it!
Sent from my HTC One M9 using Tapatalk
