TPMS Error?
Mum has a 65 plate Citigo and the other week I checked her tyre pressures. Some were a bit low so I topped up and reset the TPMS.
Then yesterday the system came up with an error and won't reset/clear.
All pressures are OK and everything else is good. Appears it has an error.
Anyone else had this?
Car has only done about 6,000 miles, isn't used heavily. Mum is 73!
Sounds like a wheel speed sensor has failed. Book it in for a check at the dealer.
That's what I suspect.
Got it booked in for next Friday (8th) so will update then.
Will double check all the tyres before it goes in and just make sure there isn't a screw or nail in one of the tyres causing the error, but I suspect not.
