Eml on due to sai removal?
Evening gents, what error code would the removal of sai throw up on my little orange
Plug in reader? Can the fault and eml be cleared?
did you put a resistor in after sai removal ?
Hi, thanks for the reply.. going to view a car in the morning! Eml on as a result of sai removal.. so just trying to get a heads up on it
that will happen ( I have it mapped out on my car , so no warning light) you can add a resistor to prevent the light coming on...... IF the seller is being honest and thats why you have the light ;)
Can you get mobile data while you're there? If so Google the code. As said the owner should have put a resistor in (they may have and it's not worked, don't always) or had it mapped out. If they're the kind of people who half finish a job like that alarm bells are starting to ring, just give the car a good going over to be sure.
you may code a code similar to this :
1 Secondary Air Injection System Insufficient Flow Bank 1
quite common if the SAI has been deleted or unplugged or generally faulty. most folk map out that code when removing or deleting the Sai as fitting a resistor does not guarantee the fault will not appear.
Edited by Bowders1
