Symphony head unit mk 1 fabia - need to test it
Morning all,
recently sold our mk 1 Fabia but still have the OEM Symphony head unit as we'd already put a replacement in the car.
Before selling the Symphony, I want to check to make sure there is no CD still in the player. Logically I would have done this before removing, but can't be 100% sure!
Possibly a very basic question, but i don't want to get this wrong.
I have obtained a copy of the wiring diagram  - can I run a cable from the +ve on the battery to either terminal 4 (ignition 12v yellow) or 7 (battery 12v red) in "Block A". And then a separate cable from -ve car battery to terminal 8 (Ground black) in "Block A"? Will this power the Symphony and enable me to press the CD button and check for a disc?
If yes, should it be terminal 4 or 7 I use for +ve? Do I need an in-line fuse on the +ve cable or will the 10A fuse on the head unit provide sufficient protection?
We do still have a Skoda Rapid but having removed the double DIN head unit, there is no obvious way to plug in and test the Symphony.
Thanks in advance for any help.
  • 7 months later...
What bluetooth enabled unit fits in best to replace the Symphony?
