Screenwash In Back Passanger Footwell!
Hi guys and girls, your all probably thinking that the ancillary carrier needs replacing but i have had that replaced, and during the last couple of days my rear washer hasnt been working, and i noticed that there was less water in the rear footwell, so today i fixed the rear washer thanks to your help :thumbup:, but i have just noticed that there is now loads of water in the footwell!!!! :thumbdwn:
I have just touched it and its very soapy and smells slightly like screenwash!!
Any help or input would be greatly received!
so today i gixed the rear washer
What??
The pipe to the rear nozel passes through there and IIRC there is a joint in the aread. I would remove the side trim and look under the carpet in the area of the wet patch. I think its caused by using the rear wash when the external bit is frozen and the pressure forces the joint apart.
The pipe runs over the rear ache
