2 types of Ap coilovers?
Are there two types of Ap coilovers? I was told there is a fatter Spring type with bigger shock piston and another version with slimmer springs and with a slimmer piston?
I was told the fatter version was better.
Any idea?
Never heard that myself, never seen 2 versions either.
Not one I've heard of relating to AP.
VMaxx have oversized dampers with thicker rods.
Hmmm interesting, does anyone have a pic of the springs that come on them? Are that a fat shaped spring or the slim type seen in the pics that they use on eBay? (I'm wondering if they're just generic pics)
  • Sponsor
Only one type of AP coilovers for the Fabia 6Y.
Damian @ DPM Performance
Cheers Damian do these have a fat spring or slim?
  • Sponsor
Can you explain what you mean by that? Are you mean the actual spring coil thickness or the way the spring has been wound?
Should be a progressive spring which I guess you could call fat.
Like that
[ACC2850B-CE78-4FA9-97FE-84CD3188C0DD_zps
Just incase, your not getting mixed up with the helper spring or somthing that some coilovers have?
There are stock pictures used when selling APs that have a dual linear spring setup. Perhaps that is whats causing the confusion? I don't think they do a setup for the Fabia like that though, its probably just a setup from another car.
Yeah sorry guys, I was just going off what I was told. The picture above shows what I am describing as a "fat" Spring.
