TCS Light and Glow Plug System Light appear
Hello everybody!!
I'm driving a Skoda Fabia 5J (diesel) from 2007.
Everything was working great until yesterday when, out of the nowhere, the TCS Light and Glow Plug System Light appear on my dashboard.
The TCS Light is turn on and do not blink. The Glow Plug System Light is flashing.
Since i've an VCDS cable, i plug it into my car and the log was:
Friday,15,April,2016,18:59:38:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: TMBDF65J683016640   License Plate:
Mileage: 145520km-90421mi   Repair Order:
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBDF65J683016640   Mileage: 145520km-90421miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 045 906 019 CD
   Component: 1,4l R3 EDC G000SG  9745
   Coding: 00102
   Shop #: WSC 13765
   VCID: 59A19A97091982FA381E039-4B00
   TMBDF65J683016640     SKZ7Z0G4284595
1 Fault Found:
16955 - Brake Switch (F)
            P0571 - 35-00 - Implausible Signal
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ASR80.lbl
   Part No SW: 6Q0 907 379 AM    HW: 6Q0 907 379 AM
   Component: MABS 8.0 front  H03 0001
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0000115
   Shop #: WSC 13765 790 00000
   VCID: 08078FD3E233CE7257308E5-5124
1 Fault Found:
00526 - Brake Light Switch (F)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 43
                    Mileage: 145524 km
                    Time Indication: 0
Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
   Part No: 5J0 907 044 A
   Component: CLIMAtronic SK25    0608
   Shop #: WSC 00000 000 00000
   VCID: 2847EF5302F3EE7277F06E5-5140
No fault code found.
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E6B290BF07745C22D0C78D-5124
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: 2745EC6F0FEDE40A7EEA651-5124
Address 16: Steering wheel        Labels: None
   Part No: 5J0 959 441
   Component: MF-Modul       0005 0260
   Coding: 0000001
   Shop #: WSC 13765 006 00000
   VCID: 6FF5C44FE79DF94AF63A1D1-5140
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 810 C
   Component: KOMBIINSTR.    V2823466
   Coding: 19104
   Shop #: WSC 13765
   VCID: 265BE16B08E7FD02451C70D-5124
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000E GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70F7C733FAA3E3B2EF00065-5140
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2823466
   Coding: 19104
   Shop #: WSC 13765
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10110
   Shop #: WSC 13765
   VCID: 6FF5C44FE79DFC4AF63A1D1-5124
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 5J0 959 433 A
   Component: 03 Komfortgerát     0001
   Coding: 00019
   Shop #: WSC 13765
   VCID: 317102373129AABAA08ECB9-4B00
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 5J0 035 161     HW: 5J0 035 161
   Component: Radio FO3       010 0029
   Revision: 00010000    Serial number: SKZ7Z3G0011860
   Coding: 0000400
   VCID: 5FD5B48F173D69CA46DACD1-5140
End-------------------------(Elapsed Time: 03:49)--------------------------
Can someone help me? If someone can help me, or have a clue?
Thanks in advance
André
  • Sponsor
You need to replace the switch on the brake pedal.
Hello,
Thanks for the quick reponse.
I'll look for the switch on the brake pedal. But what about the TCS light?
Thanks in advance,
André
  • Sponsor
Probably a consequence of the switch failure. Fix the obvious fault, see if any problems remain.  I don't know the procedure for a Mk2 Fabia, maybe try asking in that section. There's a guide for Mk1 Fabia in the Skoda Fabia Technical Guides area, I should think it is very similar, just maybe a different way of removing trim panels to get to it.
Thanks a lot for the help.
I will try tomorrow and give feedback.
Andre
Andre
Seconded - change the brake light switch.
You are getting warnings as traction control is confused
Sounds like it to me, too. Had similar and blown bulb. Throws up fault lights till its replaced. Not expensive but in all, cost about £120 for diagnostics, new switch and bulbs plus fitting. Switch is around £20.
brake switch is a common problem,
its a pain to get to (unless car is on a lift) right up top of pedal,
twists out from memory then undo wire , reverse process to replace
the switch has two sets of contacts, one is the brake light the other goes into ECU I think, so if you brake it reduces engine power and a few other things like disengaging cruise control ( if you have it )
Hello everybody,
Finally i had the time to change the stop bulbs and the switch.
After changing, connect the car to the computer, cleaned up the erros and everything works great now :)
Thanks a lot everyone :). Just save a lot of money, and learn something on the way :).
Thanks a looooooot :)
Cheers :)
Thats great... We'll all "SEE" you  in the pub later! :cocktail:
glad to be of assistance
