VRS feels like it bogs down
evening all, I'm after a little help when I load my car up it bogs down(comes on boost and holds back massively) , was wondering if anyone else has had this problem and could guide me in the right direction, I've already replaced coolant temperature sensor, fuel filter and coil pack
Thanks Andrew
Any error codes? Is it a flat spot in acceleration or does it go into limp mode?
No error codes, if I press the peddle half way and build the revs up there isn't any problem, it only happens when you go full throttle its like it gets no fuel
Tried new plugs?
Yeah plugs were done late last month, thanks for the replays
Air filter?
Air filter and fuel filter. Also what petrol do you use?
I only run mine on VPower. As everything else makes it feel sluggish
Sent from my SM-G900F using Tapatalk
It has a s2000 air filter behind the bumper so could be dirty will remove front bumper and have a look, fuel filter was done Wednesday, I run my car with v power. Thanks again boys
Hi Fanvrs I'm having the same problem as yourself have you found out what is causing it. I have had a new n75 new filters new plugs. Oil change and serviced. Been read on vcds and nothing comes up. Driving me mad now
Hi Dps1983 I did eventually fine the fault, in the end it was fuel pump failure. Hope this helps, cheers Andrew
