(PAS) Wheeal still hard to turn after replacing power steering pump!
Hello everybodies. I'm sorry for my bad english. I'll try to tell you my problem with fabia and wait for your help.
The light of the  PAS turn on sometimes and in VCDS i have these faults codes
Adresse 44: Direction assistée        Labels: 6Q0-423-156.clb
   No. pièce: 6Q0 423 156 G
   Pièce: Lenkhilfe           0004
   Codage: 00110
   No. Atelier: WSC 00000
   VCID: 3365E925014D1B8659B-5072
1 Code défaut trouvé:
00816 - Capteur d´aide au braquage (G250)
            37-10 - Défectueux/défectueuse(s)  - Intermittent
Adresse 09: Centrale Elec.        Labels: 6Qx-937-049-B.lbl
   No. pièce: 6Q1 937 049
   Pièce: BORDNETZ-SG.        1S30
   Codage: 09362
   No. Atelier: WSC 13765
   VCID: F8FF9E09D8ABB8DE2C9-5072
1 Codes défaut trouvés:
00778 - Transmetteur d´angle de braquage (G85)
            49-00 - Absence de communication
A professional man said me that i had to replace the power steering pump. So i did. I found a second hand pump. The part fitted in my car was 6Q0 423 156G and the pump that i bought was part number 6Q0 423 156 M
so I fitted new pump on my car but the wheel became very hard to turn. Can you tell me please  if i rated a state?
the second question is; in VCDS i have faults codes about (G85) and (G250). I read on the web that there are not two sensors together in fabia. Is it?
Can you help me please?
Edited by volcanomed
There is one sensor, you must replace this, the sensor is in the steering rack under the car.
As Above the steering angle sensor located in the steering column when it meets the rack, part is about £100, two small tx bolts to remove but then a very long cable from it to the PAS pump with the old cable removed & fit the new one which is part of the sensor.
Part looks like this:-
https://www.google.co.uk/search?q=mk1+fabia+power+steering+angle+sensor&biw=1789&bih=895&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwin7cWwpbfMAhVYOMAKHRC8DVEQsAQIKg#imgrc=CVhdg3FqUxF3oM%3A
Easy job, just tricky to route the wiring as all under the car... common fault/failure in these cars..
Thank you for your suggestions. I'll try to replace this sensor and hope will resolve my problem.
Thanks again
