02 110 1.9tdi water pump failure
Hey guys prob asking the impossible here... Thermostat light started intermittently flicking on/off bout a week ago but car temp never exceeded 90. No water loss either. I kept an eye on it and got it diagnosed by mechanic and booked in for replacement at his nearest convenience, wed 18/05/16. All good apart from water leaking badly now due to water pump failure. I need car for work and I am limiting my journeys. Is there anything at all I can do to reduce or slow down water leak from pump? My mechanic says no due to pump being a moving part. I would say I'm using 6 litres foe a 15-20 mile trip.
Thanks guys
Don't use the car, it'll only get worse. And you'll probably end up with a damaged head gasket if it boils, or a cracked block if you drop in cold water.
Another thing that might happen is that it could seize and snap the timing belt resulting in a potentially massive bill  :sweat:
Cheers lads I'll keep an eye and if it gets any worse I'll park her up. Mechanic might be able to get me in bit sooner fingers crossed
