Unplugging the battery
What are the steps to unplug the battery for 15 minutes?
Ignition off, does the key needs to be in ignition?
What about the radio code?
Will I loose some of the settings I have?
Anything important?
I did it recently when installing the navi retrofit for Bolero.
- opened everything I need open (door, hood, trunk if needed)
- verified that ignition is in off
- removed auxiliary plug on (-) electrode - a contact from start/stop system as far as I know
- removed (-) connector
- removed (+) connector
Work took me 1h or so. Reconnect - I did above points, but in opposite direction.
Afterwards the system showed errors on all self-learning components (abs, esp, etc) - a Christmas Tree on the dashboard so to say. Drive the car for few meters and it'll be ok.
Some report you need to teach the window closers their load/motor current set-points by holding the window switches 2s or so in each extreme position after window full movement; I did not observe that in my case.
Radio / infotainment was back online without any codes, just took few minutes.
Thanks!
Will vcds changes be preserved?
This I do not know (I'm not using it), but my bet is yes - it's just settings / program, and all that resides in non-volatile memory (such as vin, radio code, component config, etc).
