Annoying Rattle from Driver Rear
Hi all,
My 2012 Octavia vrs tdi was developed an annoying Rattle from the rear. I would say it's coming from underneath although can be certain. It sounds like metal rattling against metal. You can only hear it when going over bumps/rougher roads.
I've had a look on the search but can't really find anything conclusive.
Last Sunday I jacked it up had a look underneath but I couldn't see anything. Thought it had then gone but now it's defo back.
Any thoughts people?
Have you checked that you disc backing plates are secure? It's a common enough problem that corrosion around the bolts allows the plate to move and you get metal on metal rattling.
Exhaust shields loose and rattling?
I'll throw it up on the jack quick. I guess the best place for the axle stands is where rear sub frame meets the chassis.
I had this. The clips holding the shield over the top of the back box rotted and it was flapping around. New clips sorted the problem.
Sent from my D5803 using Tapatalk
I had this over potholes and rough ground when I had a broken spring. Slightly worse when cornering in one direction over bumps.
I too had an annoying rattle coming from the rear of the car, bit it always seemed to stop whenever the wife got out   :D
