RS Headlights on SLX
Hello guys..
I'm the owner of a Octavia 2,0 SLX. But i would like to mod it with a pair of Xenon headlights from A 2001 Octavia RS
When i do that, do i need to change the "side turn signal lamps"?
Unless you've got a pair of headlamps then this will be very expensive to do !
Do a search on here and someone has posted the complete EKTA parts diagram for all the parts needed, it shows both LHD and RHD part numbers.
Hope this helps.
Andy
I've already got at pair of headlamps from a RS, with xenon
Correct me if I'm wrong but aren't SLX models PHASE 1 Octavia and RS phase2....if so you may have a problem fitting as the headlamps are different shapes.
That is correct. The SLX has the older style headlamps where the top and bottom edges are paralell as you look at the front of the car. RS headlamps have a horizontal top edge while the lower edge slopes down towards the middle of the car.
