Rapid service reset
Hi everybody. How can i reset the service reminder on a friend's diesel Rapid? It is a2015 model with the new screan.
Use VCDS, go to the Instrument Cluster [17], Adaptation [10] and select the appropriate option from the list.
Thanks a lot πατριδα!
  • 5 years later...
You don't need VCDS, there are several ways available online to do the job - there seem to be several variations depending on specific model, most claim to be "THE way to do it"!.
On my 2014 Rapid Spaceback 1.6tdi the following procedure does the trick
  • IGNITION OFF
  • HOLD DOWN 0.0 BUTTON ON DASHBOARD
  • TURN ON IGNITION
  • MESSAGE  “SERVICE RESET – ARE YOU SURE?” WITH OPTIONS “YES” “CANCEL”
  • RELEASE 0.0 BUTTON
  • USING RH THUMBWHEEL ENSURE “YES” IS SELECTED.
  • PRESS RH THUMBWHEEL
  • -         JOB DONE!
  • IGN OFF
  • IGN BACK ON – REMINDER MESSAGE SHOULD NO LONGER APPEAR
  • GO INTO MFD MENU > SERVICE
  • SHOULD SHOW “SERVICE IN 9400 MILES OR 372 DAYS”
