check reverse light warning
Hi,
Just got check reverse light warning when shifting to reverse.
However I do have reverse light on the left side, should I have lights on both sides when reversing?
Also, I see 2 bulbs lights up on the left side (and there are 2 additional on the right, so maybe they should light up)
But my other question is, is it possible that both lights burnt out on the right side? or both will stop work when one is burnt?
Thanks in advance,
Lior
So, only one reverse light bulb on each side :) been confused by the reflector.
Went to the service center today and  it seems the light bulb is not burnt out, after opening the problematic side and playing with the bulb in its housing problem solved.
Glad you got it fixed. :)
