VRS 2.0tfsi shark stage one - become Sluggish
Can anyone help since i had a shark stage 1 remap initially it was great but now its very sluggish off the line. once the cars moving it pulls ok.
its a bit embarrassing being beaten off the line by lorries and Vans. Scan below has a few faults hopefully you will be able to diagnose. I know the miltek
exhaust has a small blow just after the cat which was picked up on the MOT but other than that it runs fine just down on power in first and second.
Im not suggesting that the remap has anything to do with the fault but i thought it worth mentioning just incase it could have a knock on effect on something else.
Saturday,23,April,2016,22:54:44:28247
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: Txxxxxx1Zxxxxxxxx   License Plate: OV55 XXX
Mileage: 142490km-88539mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: Txxxxxx1Zxxxxxxxx   Mileage: 142490km-88539miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1Z0 907 115 A    HW: 1Z0 907 115
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H10---    Serial number: SKZ7Z0E3303066
   Coding: 0203000318070160
   Shop #: WSC 00191 264 15243
   VCID: 33632295525B3FA6B3-8066
2 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 141311 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:14:35
             Freeze Frame:
                    RPM: 780 /min
                    Load: 13.3 %
                    Speed: 0.0 km/h
                    Temperature: 63.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.351 V
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 141347 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 463 /min
                    Load: 45.1 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.684 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 71EFE89D68C74DB681-8024
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B730AB57A0BF7E66B-806E
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003845862
   Coding: 818C0F030004140000110D000000000000087F075C
   VCID: 2B533AF58A6B6766FB-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 209
                    Mileage: 142324 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.45 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD02D2FZ
   Coding: 0020788
   Subsystem 1 - Serial number: 6332MSME0C46603FH
   Subsystem 2 - Serial number: 6342MSME0C411213$
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   Shop #: WSC 28061 210 64639
   VCID: 76E5DB8101A96A8E54-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 941 C
   Component: KOMBIINSTRUMENT VD1 0918
   Coding: 0003401
   Shop #: WSC 55957 001 1048576
   VCID: 377B16854623D3868F-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A208C61
   Coding: 3D3F0348071303
   VCID: 2A5D3FF185917E6E00-807E
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 0918
Address 37: Navigation        Labels: 1T0-919-887.lbl
   Part No: 1Z0 919 887 B
   Component:      Navigation     0412
   Coding: 0000002
   VCID: 479B664536C3A306FF-8012
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000756
   VCID: 36651B8141292A8E94-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.2   D06 1701
   VCID: 346121895755389EAA-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8505485F861004CC
   VCID: 79FFD0BD30B705F639-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000756
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio        Labels: 1T0-035-095.lbl
   Part No: 1T0 035 095
   Component:        Radio        0412
   Coding: 0000402
   VCID: 6BD3FAF54AEBA766BB-803E
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 326D2791AD4136AEB8-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
End-------------------------(Elapsed Time: 01:41)--------------------------
Have you checked the divertor valve? They can fail slowly until the point where your car wouldn't pull skin off a rice pudding.
I haven't checked it but Shark did say that it might need replacing. The problem is there are various revisions. Theres a metal one off the Audi s3 and an improved plastic diaphragm version. Im not sure which Letter is the best revision lots of conflicting info. I was going to get the Forge BOV. to replace it but heard bad things about that also. I think its pretty difficult to get to aswell if you don't have a ramp.
Revision G is the one you want. I'm not saying it's perfect and will never fail but it's the best of a bad bunch. Silicon diaphragm too.
Thanks for this advice. Do you have a link to one because when i phoned my local dealer they said there were a couple of diverter valve and
they ranged massively in price. Is this something i can fit myself without a pit or ramp?
It's 06H 145 710 G
On yours access will be a pain as it's underneath at the back.
It's 06H 145 710 G
