issue adaptation module 5f
I've got a VCDS 15.7.1 installed on my laptop and I need to modify some adaptation values of my navigation system (MIB1)
The issue is that sometime the value doesn't change and other software change others values.
could you help me ?
thanks
Try using the latest Beta software I know some of the older software had problems with MIB2, not sure about MIB1
if I'll try to install a pre 15.7 version ? I read in other forums could work with mib1 system.
I'd definitely go newer rather than older...
what do you think to buy ? 15.7.3 or 15.7.4 ??
