Skoda Octavia epc light
Hi all
I have a skoda vrs and the epic light come on and the car won't Rev also keeps coming back with the following engine manAgement codes
The car was left standing for 12 days while on holidays and then won't go hose it and all these problems arised.
16622 /P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
18047 P1639/005689 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
18042 /P1634/005684 - Accelerator Position Sensor 2 (G185): Signal too High
17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
The car has had a new pedal and a new map sensors (Bosch sensor)
Wired get check from pedal to
Check all wiring to Ecu and Ecuador it self seems ok no water ingress
All vacuum pipes pressure tested
Any help with be grateful as I'm scratching my head
Many thanks
