Retro Fitting Options
Is it possible to retro fit items like tyre pressure monitors and light assist to octy II's after build? I ask this because it seems to me that other than the switches or sensors I cant imagine that VAG would go to the effort of producing more components than they need to so something like light assist would simply need a replacement switch and then have VAG COM adjust the setting as I am pretty certain that the rain sensor will work for both. My thinking of this is owing to the retro fitting of cruise in the octy 1 was straight forward enough so maybe other things can be done.
The tyre pressure monitor simply consists of adding a dashboard switch to wiring which is probably in place and a bit of re-programming. Probably similar for for light assist but I doubt you could retrofit these 2 options for less than £95 which is the total cost if you spec them in the first place.
The cost doesnt bother me too much I would expect it to cost more to be done after it had left the factory, it was the 3 month delay in getting the car with the bits I wanted that put me off.
  • 4 years later...
Tyre pressure monitor works off the ESP sensors, so will be standard with that and not possible otherwise?
Hi
I have retrofitted TPMS to my Golf should be the same with the Octavia, just need the TPMS button for the octavia.
http://www.worldimpex.com/assets/partdocuments/TPMS1.pdf
http://uk-mkivs.net/forums/t/299640.aspx
http://www.kufatec.de/shop/product_info.php/info/p907_TPMS---Tire-Pressure-Monitoring--Harness-VW-Golf-5-Golf-5-Plus.html/XTCsid/e8777ff5cc9341c49e0fb446ebb6e5c5
***Bump***
Does anyone have the part number for the dashboard switch please?
Found my own answer... and a tutorial - albeit in German....
Taster fur Reifendruckkontrolle 1x 1Z0927127B
Steckerhehause 4DO 971 636 B
2 x Satz Leitung 000 979 002
Satz Leitung 000 979 131 A
Schneidverbinder rot Red Cutting Connector is the translation - I assume this means red scotchlocks... eek... maybe something else will be better.
Einzelader 1mm Querschnitt Single Core Cable
Schrumpfschlauch Heat Shrink Tubing
