Abs Fault code 01314, 013
Please help my front left and back rear right brakes come on without warning and for no reason.
Had the codes read using the VAG software
Address 03 ABS Brakes
Part no. 1c0907379k
Component asr front mk60 0103
Coding 0021505
Shop WSC 73430 790 00000
Vcid 3260F9A0AEA7BCAEB8-515A
1 Fault found
01314 - engine control module
013 check dtc memory - intermittent
Do I need to replace the ABS pump
Edited by briaineo
  • Sponsor
What is the fault in the engine control module?  I think the 01314 fault you have in the ABS controller is merely it saying "hey, go check the engine module, it has a fault"
These are the faults under address 01 engine
Can't seem to see one dedicated to ECM
16725 camshaft position Spenser
17911 load signal alternator term DF
19557 motor for intake manifold
17964 charge pressure control
18263 power train data bus
There seems to be no address 22 on report, from what I see from other reports this is the ecm
  • Sponsor
That's the module I meant, 01 Engine.
Plenty of problem-solving to do there then.  DF/load signal is an interesting one to start with perhaps, can cause other modules to get upset because it can result in poor charge management as the other systems no longer know how hard the alternator is having to work, assuming flat out by default I think.
Look for a broken thin wire somewhere between alternator and engine ECU.
Actually as its turns out it wasn't the ABS causing the brakes to lock on but the push rod going into the master cylinder seems not to return sometimes!
