Brighter Headlights: Definitive Answer PLEASE!
Firstly, thanks to Chris et al for all the testing / research.
In conclusion;
What is the best ( non - Xenon ) upgrade for Furby's
1) Dipped Beam
2) Main Beam
........and who's the best / cheapest online supplier.
Thanks, Guys :thumbup:
John.
PS. Legality bothers me '**** - all'.
PPS. Blowing a loom bothers me period!
1 silver stars
2 philips rallye
i used power bulbs
1 silver stars
2 philips rallye
i used power bulbs
What 'e said! :D So good, I even got a set for the Mondy! :rofl:
Chris
Firstly' date=' thanks to Chris [i']et al[/i] for all the testing / research.
In conclusion;
1) Dipped Beam
2) Main Beam
John.
Osram Silverstars I got from Crazy skins on Ebay for
thats 32 quid for bulbs are they really that good?
Yep - the difference is VERY noticable (and that's with the legal lights, let alone with the ralley bulbs ;))
I'm going with H7 superstarts and 30% H3 when funds allow just hope they are OK on Projection lamps
Either the Phillips Vision + or the Osram Silver Stars for dipped.
Phillips Rallye bulbs for main
Devonutopia posted piccies of his with that combo
The SilverStars and Rallye bulbs are fine on the Mondy's projection headlamps :D
Chris
Has anybody ever tried or used the PIAA Platinum White headlamp bulbs on H3's,as it say's they draw 55w but produce 85w and also 'E' rated may be a useful compromise between standard and fitting relays etc to run 100w's. As i'm going to the autosport show on saturday may have alook if there are any bargins going!
A lot of biking mates use Philips GT 150's, i might give them a try in the vRS.
What ybout those with xsenons? I understand that Fabia has only dipped xsenons. So what bulb should I buy for main beam to give the best result?
the 100w rallye bulbs
Someone on here posted that 100 watters will damage an o ring ir seal in the HID headlight shell.
Still thinking about dual HID. Any thoughts?
Chris
rodpix, I have. They are expensive (twice the price of the Osram and Phillips ones. You'd be pushed to notice the difference.
I've been using 100w ones in my one with Xenons for the last 90k miles - my seals are fine.
