Misfire under load, can I have some advice please?
I have an 09 Facelift petrol VRs
Was driving home from work today and the car misfired all the way home particularly around 2000rpm and under load, eventually the CEL started flashing then the EPC light came on. The OBD only logged two faults even though it misfired all the way home, about 8 miles.
Diagnostic from VCDS is:
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0010
   Revision: AAH11---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 73430 790 00999
   VCID: 79FC6A87308BBE8AE4-802C
2 Faults Found:
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 88091 km
                    Time Indication: 0
                    Date: 2010.12.23
                    Time: 17:17:25
             Freeze Frame:
                    RPM: 2021 /min
                    Load: 90.9 %
                    Speed: 72.0 km/h
                    Temperature: 96.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 88096 km
                    Time Indication: 0
                    Date: 2010.12.23
                    Time: 17:22:48
             Freeze Frame:
                    RPM: 4083 /min
                    Load: 87.8 %
                    Speed: 58.0 km/h
                    Temperature: 93.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Would i be right in thinking coil packs?
To be sure, swap the coil pack for cylinder 1's and see if the fault swaps over, that way it pretty much proves its the coil pack and nothing else
Edited by SuperbTWM
Thanks for the advice, the misfire followed the coil pack, so next question is where is best to get good quality coil packs on line?
Are the red R8 ones any good or am I better of with OEM ones?
Also, am I right that I should replace all 4 and not just the failed one as they're all likely to go soon?
The R8 ones are OEM, probably exactly the same coil as the one you would get from skoda only red. I would get a set of whichever is cheaper.
You could just replace the faulty one though if you wanted.
If you replaced all four packs, you would have three spares for next time IF, one fails ?
Firstly, a flashing MIL indicates a live engine misfire, and secondly engine misfires under load are usually due to a high tension (HT) ignition fault, such as an ignition coil or spark plug/s.
