06 l&k rear shock help
as per title I wonder if someone has a part number for the rear shock absorbers on a 06 l&k Octavia estate,
ive just replaced the rear trailing arms as my motor seemed to skitter so to speak at rear whilst cornering, bushes in the trailing arm were separating from the bush housing, but whilst replacing noticed the shockers at rear are weeping and the motor still feels loose at rear end when cornering so gonna replace those too
If it's a 1.9 PD105 L&K with sports suspension and 17" Pegasus wheels the part number is:
1K0 513 029 GB
The number is stamped on the shock body!
Edited by MicMac
well I cannot see the sticker on either rear shock, nor did the car have original rims on it when I bought it
yes it is a pd 105 bhp L&K
The shock part number isn't a sticker it's physically stamped into the metal.
Look at the sticker on the boot floor to see all the option codes your model has, use this to find out which shocks you need.
There is an option list on this forum to help you decode the sticker.
thankyou very much
