Vrs silicone pipe change help
Hey people. I recently bought a silicone pipe kit from eBay to replace the pipes connected to the turbo etc as I had a boost leak (thought change them all and make them look mint at the same time. I have two pipes left and have no idea where they are. I was hoping someone has changed all the similar pipes and have an idea where they are.
Here are the pipes I bought
Engine looking better
The pipes I have left :(
Think the one on the left is probably to replace the S pipe under the inlet manifold, which is notorious for splitting.
Is the pipe you mean the one part of the crankcase breather system as I have changed this one already and is a bit different. Joins to a T bit,
Ends up pretty much near the bottom of dipstick?
I will have a mooch under that part tomo, cheers :)
Yeah it connects from the underside of the manifold to the PCV valve that sits in the big T piece.
