Getting hold of XP or Win98
For what it's worth... I found we could run dos stuff in linux for less cpu than a modern windows os, forget which one the last dos bit was in.
Anyhow you might find... run a linux vm; might as well go ubuntu for most online documentation, then install wine, it might work! It will be an experience to find out anyway.
I use wine to run firefox, because 4OD and other services don't support chrome or firefox under linux, so I run wine for firefox, ta-dah thank you.
I had a brief look into doing it in WINE, couldn't find much info of any having success.
Buy yeah might be worth doing a 'nix VM for experience. I've not played with it for a while.
Thinking about building a new PC soon and I'll probably dual boot that.
Bit of reg hacking might have done the trick
http://www.wikihow.com/Make-Windows-XP-Genuine-Forever
It's disconnected form the internet so updates not really an issue.
Edited by Aspman
Take it back, didnae work
Bit of a reminder for folks using W98- REMEMBER to use the "safely remove" tool on ESPECIALLY USB drives before removing. Most times W98 is OK, then she gets like a woman scorned and you've got fried USB drive ( like that with fries Sir ?).
Actually found my old copy of 98SE.
It's like internet archeology to get bits to make it work. The newest VirtuaBox VGA driver I could find was form 2008.
Then I check the box and it says Pirates doesn't work on Win98. Seems to be installing though.
