ECU help Please
Probably got confused now. Need to delete learned values with VCDS.
could need the keys re-programmed with vag-com
So if I download VCDS and use that hopefully it will work. I have a KKL VAG-COM for 409.1 lead will that suffice??
You absolute stars downloaded VCDS and its gone out.........................brilliant help from you guys. Thank you.
You're welcome :)
