Coolant leak - intercooler?
Looks like the slight coolant leak I've had for a few weeks is worsening and the only place I can see any sign of possible leakage is intercooler area ie below RHS front bumper.  If the intercooler - is this a big (expensive??) job to fix?
cheers
There isn't any coolant in the intercooler.
Aha right it's an air radiator.  Oh well - will keep on looking for leak.  Hoping not head gasket but motor seems to run fine once warmed up for a few minutes........does burn a lot of oil though.....   :coffee:
How far forward is is? If it's under the bumper then you'd suspect it's the radiator. They usually leak in the bottom corners but you'd have to go underneath to see it properly
