Felicia thermostat issue
hi all  skoda members i am from Egypt and my felicia 1997  thermostat is removed i searched over my area to look at a new one work at 80c i didnt found i have found only a china one works have opening  temp 88c and i dont trust also my country  have hot climate over the year so i wonder if any thermostat from other brands fit my felicia or not and many thanks
i am looking for thermostat like this in other car brands if any know thing please tell me
You forgot to tell us what type of engine has your car.
Also what is the outer diameter of the thermostat.
Edited by RicardoM
If you want to buy only the thermostat, you can choose from the following manufacturers:
  • BEHR HELLA SERVICE 812523
  • CALORSTAT TH4608.80J
  • DELPHI TMS1221
  • FACET 7.8465
  • FAE 5320380
  • GATES TH12480G1
  • MOTORAD 209-79J
  • VALEO 820541
  • VEMO V15-99-1911
  • WAHLER 303280
Note: The outer diameter of all thermostats is 60 mm. They fit only if existing housing can accommodate this diameter.
If you have a thermostat that is held in place with a securing ring (see photos), the outer diameter is 46 mm! You can't find replacement for it. There is a solution though: use a thermostat housing from Skoda Favorit.
  • DELPHI TMS1221
  • FACET 7.8465
  • FAE 5320380
  • GATES TH12480G1
  • MOTORAD 209-79J
  • VALEO 820541
  • VEMO V15-99-1911
  • WAHLER 303280
how could i know that the above thermostat will fit my house or not expect remove the hosing or there is another way
how about the china thermostat that work at 88c
If the thermostat on your car was bought by you as a whole (thermostat + housing) then inside there is:
  1. a 46 mm thermostat held in place with a securing ring (see photo 1) or
  2. a cheap Chinese thermostat held in place by two hooks (see photo 2)
The first thermostat is more reliable, the second one is rubbish. Don't even bother buying Chinese parts. Ever.
As I said before, the best solution is to buy the cap of the thermostat housing (see photo 3) that will accommodate a 60 mm thermostat. By doing that you will never have to buy each time a new thermostat housing but only the thermostat. Moreover, you can select a very reliable thermostat from many reputable manufacturers. A high quality thermostat will keep your engine away from overheating followed by other expensive problems.
Edited by RicardoM
i found the house with thermostat but it was a china too works at 88c and dont trust i have problem with some genine parts :sweat:
how about the fan thermostat my car have 82-68 thermostat should i replace with 90-80 becausse the car in hot weather go to 85 c and fight to get 70c and that is wrong issue
The thermo-switch for the radiator fan should be 88-79 for hot climate.
does thermo-switch 88-79 work for both coolant thermostat 80c and 88 ?
You live in Egypt, a country with hot climate, right? So it is logic to use both a thermostat and a thermo-switch with lower operation temperatures. I thought you have that sorted.
Thermostat: 80 C
Thermo-switch: 88-79 C
Thermostat: 80 C
i asked because i didnt found the 80 c thermostat i found the 88 c and i know it will dont work well with hot climates it was just question
