Climate fault pre fl vrs
Hi all,
I've got a problem on my vrs.
The drivers side temp will not adjust from freezing cold however the display says it's a higher temp. The only way I can get it to go hot is to turn to HI and then as soon as u start to turn down it goes back to freezing cold. The passenger side is working fine ? I've scanned the car and no faults and also reset the flaps etc in vcds.
Anybody got any ideas ?
Could it be the actual panel is faulty?
All ideas are appreciated !!
Thanks Dan
Sounds like a temp sensor behind the vents might have come adrift.
I have exactly the same problem, but on mine it's the passenger side. Been meaning to investigate :)
The ones behind the centre vents are in place, no idea where else to look
Anyone ?
