Parking Ticket Holder
This is obviously not the most critical piece of kit on the car but it's lost its spring! I purchased part number 1Z0867159A, as a replacement, as it said this was for a Octavia/Fabia but it doesn't fit! I found something that said 6Y0867159 is the correct part.Is that right?! and does anyone know where you can get one please!
I just bought a universal one on eBay, works perfectly.
Blu Tack works quite well.
Do you mean the clear plastic clip bottom right of the windscreen?
If so I brought one a while ago, I have looked through my receipts and found one for a 6Y0867159, the description is 'R106 Bracket FO'.
It cost 24p + vat so I suggest you go to a Skoda dealer as its not the sort of thing you will find elsewhere.
  • 5 months later...
Had some things done to my car at the garage today, and asked them to fit a new ticket holder on the windscreen (6Y0-867-159). It's not tight against the windscreen and does seem very low down?! I know it's a bit OCD but it's irritating that it's not doing what it should i.e. Hold a ticket!
Thx for this. Mine broke a little while ago. Time to order a replacement. I'd guess that the A pillar trim must be tightly clipped in for it to work.
Nope, it fits against the a pillar metal and should be tight against the windscreen without the trim in place
as said previously its 24p so maybe order 2 in case it breaks again
If I remember correctly the clip is held on with a torq screw behind the trim
yep
It's not tight against the windscreen and is sitting some way from it.You definitely couldn't put a ticket behind it and its as ineffective as the old one! Why are the most simple things the most awkward to fix!
