Soft plastic cracking
Just cleaned the inside of car yesterday and on the door card where the window goes down,probably where we put our arm on to rest,a crack has appeared? A splitting of the foam/trim the car is 5 years old vw golf , is there anything i can do ?
That's terrible. More perceived Volkswagen quality. Or rather lack of!
Yes probably down to high temps and cooler nights ?
From VAG POV it's not an arm rest so your fault.
I was sure it's a common issue but a quick google brought up nothing.
I guess it depends how fussy you are, with a bit of care some superglue might fix it well enough or go to a trim repair specialist.
I dont rest my arm we use the arm test on the door is as im a short arse my harm doesnt reach that far i will see what vw dealers say? Or failing that superglue will probably do the job
