Rear lights now available
Not suitable for right hand drive though.
Is it not the same as VW's you just need to cut the fog light hole ??
I had a set of these, absolute pain to get both sides to match. when they mad them they put a red reflector in between the clear lens and the actual silver back and you can't get to it from the back, the only way I could see to remove the lens is take the clear lens cover off, take out the red reflector and then put the lens back on, right ballache. still have those lenses in the garage, may attempt to do something with them!
Are there *any* after-market rear lights for the Mk2 that work for RH drive? Because I do like the look of the darker styled ones.
I have emailed the makers of the ones I've had (mostly based in Korea) haven't heard anything as yet, may chase them at some point.
