Whits end
2yr Citigo 20k miles  - creaking back suspension / wobble at low speed.
been back and forth to the skoda garage - i was told the woble was the rear tyres uneven wear and maybe a buckled rim ( replaced both back tyres and rims ) still feel it at low braking ( like surfing )
Creaking 3 times its been in - for both sides and was told door latches and pillar - last time in last week it was endoscope via rear panel ( creaking is now back not as bad as previous )
john
do you have a spare wheel in the boot?
if so swap the front wheels for the spare one at a time and see if the wobble goes away? that would eliminate front wheels and tyres one at a time
is the wobble felt through the steering or your rear on the seat?
you may be able to isolate front or back yourself, you seem to indicate it is light braking, if lowish speed,
do you have a straight and quiet road near by? if so when no other traffic on the road get up to the relevant speed and GENTLY apply the handbrake just enough to gently slow the car down, (you will get a warning ding  and light on dash to let you know handbrake on while moving ) and see if you get the wobble, if not its likely the front brakes / wheels will need further investigation
