octavia mk2 BKD 2.0 tdi cutting out
Hi all been having a cut out issue today 4 times on the way to work and 2 times on the way home. on the 4th times on the way to work i spent about 20 min trying to get it to fire up it was turning over but not firing.
the only thing i can see amiss from under the bonnet is the anti shudder valve plug is broke so it wont stay clipped on. it just so happened when i pushed it back on and it fired up after a few cranks.
i have done a log trough vcds below. i cleared all the codes and took the car for a drive no cutting out and no codes come back. can anyone help or had this problem and fixed it?
Monday,19,September,2016,15:32:26:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBBE21Z372064440   License Plate: AFTER CUTOUT
Mileage: 190780km-118545mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 36 42 44 46 52 56 62 72 76
VIN: TMBBE21Z372064440   Mileage: 190780km/118545miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 LD    HW: 03G 906 021 LD
   Component: R4 2,0L EDC G000SG  8514
   Revision: --H05---    Serial number: SKZ7Z0F3834966
   Coding: 0000072
   Shop #: WSC 73430 790 00000
   VCID: 6CD7223B4F7E2C7E58B-8039
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DA5776E8867E6AD9-806A
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004493410
   Coding: E18A8F231004140000110D000000000000097F075C
   Shop #: WSC 17009 576 03133
   VCID: 2B55E1278AF0EB46111-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 17009
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     031006 014  1201
   Coding: 00471077
   Shop #: WSC 17009
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 250
                    Mileage: 190709 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 14.30 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0T2YYJ
   Coding: 0020788
   VCID: 3D71DF7F648475F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME122536640
   Subsystem 2 - Serial number: 6342MSME124568165
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 8109E38FD8FC51161BD-80D4
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0F3834966
   Coding: 0007401
   Shop #: WSC 14557 604 69422
   VCID: 3979CB6F70AC49D693D-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001069051440
   Coding: 3D7F074007001303
   Shop #: WSC 73430 790 12345
   VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 250
                    Mileage: 190707 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:20:06
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
   Shop #: WSC 00000 000 00000
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D51EF3FB4E4E5760F5-8078
1 Fault Found:
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 E    HW: 1T0 959 701 E
   Component: Tuer-SG         005 0946
   Coding: 0001014
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 01801A085283007F3F02050FC008DF96907C00
   VCID: 8305E987C2E04306091-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 250
                    Mileage: 190709 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:22:18
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 E    HW: 1T0 959 702 E
   Component: Tuer-SG         005 0936
   Coding: 0001014
   VCID: 3A7BD46375AA42CE9A7-806F
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377DCD5746B85FA6659-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
   VCID: 387FCE6B4BA650DE6C3-806D
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End   ---------------------------------------------------------------------
