Window control module
If replacing the control module for an electric window does it require coding ? My window was inop (pax front). I've replaced the module from a doner regulator. Window now works from pax door but not drivers. Also central locking inop on said door and rear windows go down in stages from drivers control ?
Yes, unless it happens to be from a very similar donor vehicle :)
Ok, how do I do it ? I have vcds.
So was going to leave as is because window was working from PAC door. But after leaving car off for 5-10 mins window no longer works unless module disconnected and reconnected !! Looks like I need a log in to access the coding as it is greyed out. The old module shows the fault input voltage too low whilst the new one shows Comms fault. Any ideas ?
Might help if you post up the part number from your original motor and the one you have fitted
Also have you checked the wiring between the car door and car body to rule out damaged wiring
Checked the wiring, all looks good. The low voltage fault code is only for the original module (I have only replaced the black control module not the motor). With this installed the switch lights up and the central locking works. With the donor module the window works from the passanger door switch but not the drivers. Also the switch doesn't light up and the central locking doesn't work and the rear windows operate in stages dmfrom the drivers button. The fault code is a communication error with this module installed.
On white stickers on module:
101449 203 05 765 70 , H1.20 S2.7 080101 , 14 1951 - The "New" module
104417-302 05 742 70 , HW12 S0202 15025 , 23 2328 - Original module
PA6-3F40-TPE appears on body of both
part numbers for door controllers would be something like 1T0 959 701 for the drivers side and 1T0 959 702 for the passenger side
the box module bit would start 1k0
if you got the box from say a vw golf even if the part number is the same, some functions would work differently
Is that P/N for the motor/module assy ? I got the whole regulator/motor assy from the scrappies yesterday so it is definatley from an Octavia. Is there any coding that can be carried out ?
window motor consists of two parts
Motor = 1T0 959 701?
Module = 1K0 ? can't remember the rest
You can't order the module from the dealer, you have to buy the full motor.
The motor part number will show when you use VCDS
2012 Model year
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
2006 Model year
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2438
Even though both controllers are from an octavia, the two listed above would only work in the same model year
Cheers Eddie. I'll scan the car again tonight. Thanks for the assistance. Looks like £30 down the drain but hey-ho !
Ok - P/N of installed motor is 1U6959801D and one from the scrappies is 1U6959801B. Could that be the issue ?
I would say they are for the mk1 Octavia
Yes, it's on a 55 plate so it's on the cusp of mk1/mk2 confusing things more ! Would the B/D prefix cause issues ? Does the control module need to stay with the motor as an assy ?
mk1 parts are not for the mk2
what was your original part number? that is what you should look for
The car is a MK 1 , must of been registered late. That is what causes problems as everywhere thinks it's a mk2. The p/n with the suffix D was the original, B was the replacement. I've ordered a motor with the Suffix D (same p/n) , seller says it's from a 2007 mk1 ?
What does the B and D mean ? A later mod state ?
Also I realise this is the mk2 forum. Had the link stored when I had my mk2 and posted on auto-pilot - apologies for using the wrong forum.
In a nutshell - the car is a 55 plate vRS mk1 estate , P/N: 1U6959801D is the failed unit, same number with a suffix B does not work (from an 03 Octavia). Can anything be done through VCDS ? What does the suffix B and D denote ?
Mule
as it is a mk1 that does make a difference
Door controllers for a mk2 require to be coded correctly for functions to work. The mk1 door controllers can't be coded, so should work without coding.
In that case is there something else causing the issue or is it the suffix B and D ? There was a slight difference between modules so maybe that's it ?
So from doing more google research the end letter is indeed a mod code. Even if they share the same base P/N they are not necessarily interchangeable so I'm guessing the B and D is the issue. Will find out in a couple of days !
Motor Assy with the Suffix D has arrived and the good news is it has the same P/N: 104417-302 05 742 70 on the module as the old one ! Hopefully get it fitted today and will update.
Happy Days !! Just the ticket - now all working as advertised :)
Edited by VrsMule
