Superb Mk1 Alloy wheels
Hello guys
I am getting Superb mk1 alloy wheels at very cheap price , I want to know will it fit on my Pre-fl Octavia
These are the Superb's alloy
These are mine L&K Pre-fl Octavia alloy
The mkI superb is 5x112 so that will be OK. What size and offset (ET) are the superb wheels? Do they have tyres fitted, if so what size?
I will use my own tires which is 205/60R16 Michelin
They aren't the right size tyres for a mkII octavia. They should be 205/55/16.
Ya I know , Been using it past 2 years, In India Roads are not good as it should be . 205/60/16 raise it a little bit which helps a lot
Raise the car by just over 20mm and also change the overall gearing by 3-1/4%. So your speedo will read about 2mph under 'true' speed, but as 'true' speed is almost certainly reading fast you may well end up closer to the real true speed.
I run higher profile tyres too and I live in the UK, bad roads aren't exclusive to India  :D
