intermittent starting problem 1.9 TDI
Hi
I have a intermittent starting problem with my skoda octavia 2003 1.9 tdi. The problems are many but I think they all relate to single cause :nerd:  (i hope)
Sometimes when I turn on the ignition, all dashboard lights do not glow with full strength and wiper also move quite slowly and engine does not take crank. I switch off and switch on for number of times and then all seems normal  :clap:  .
During this process, sometimes mileage counters resets and my electronic parking clock also initializes.  :envy:
The central locking system also not functions properly.... some time it requires couple of pressing to open the lock. and sometime alarm starts buzzing as soon as I open the door.
However the car runs perfectly mechanically.... i have recently spent a lot of money on breaks etc just to keep the car for next couple of years and now this happens :sweat: ... Is this problem something to do with ECU or locking system :nerd: ?
Any comments will be much appreciated. Thanks !
Have you checked your battery?
Sounds like that or a poor earthing point to me
Sounds like a dead cell in the battery or could be the fues box on top of the battery or even the ignition barrel. I'd go for battery firstly, get a new on, and see if that cures the problem.
good thanks !
Battery is two year older... how long does it last  :notme:  ?
A battery should last more than 2 years.
Check the terminal cables, and the battery top fusebox (which may be getting hot).
There should be a 3 year warranty on a battery but anything is possible with a battery as it depends sometimes if they have sat for a length of time before being sold. You need a drop test done on the battery, check all connections on the battery and also check the charge rate when engine is running.
Hej I have tighten the nuts of battery and replug the 3 fuses on top of it. Since than no problem :sun: . Thanks for the help.
  • 5 months later...
Hi the problem backs again :(.. please helppppp
The car either takes a crank or does not take crank. when it takes the crank than violla engine start on the first shot.. if it does not the battery light dims and rest not.
I understand if the battery is poor, engine start after many weak crank or may be i am wrong ?
recently there is a problem with wiper relay 377 which i replaced but the problem above was from earlier days.
Edited by kthned
