Vrs lower suspension bush change query
Hi guys
Took my 2010 vrs tdi in for service and they gave me a list of advisories some of which I knew about and some I didn't.
Basically new front shocks, front discs and pads are in order plus the lower suspension rear rubber console bushes have perished.
I've done a search on here
and I like the idea of popping in an S3 bush but my question relates to changing the associated bolt.
Can anyone point me in the direction of where I can buy replacement bolts as I've read its a good idea to do it when changing the bushes.
Many thanks for your help
Try you local TPS or Skoda dealer for the bolts as all they need is you car reg and they will be able to get the correct bolts for your car.
On my petrol VRS, I got all of these bolts at the cost of about £28 from TPS. These are all the bolts needed for a full suspension kit fitting:
N 10127707 x 6
N 91021601 x 2
N 0150816 x 2
N 90954802 x 2
N 10106402 x 2
N 10332002 x 6
I re-used mine.  The world didn't stop turning.  We don't get corroded fasteners down here though.
