Help Please, Number Plate Light VCDS Coding issues
Hi,
Hopefully somone can help...  I have replaced my number plates bulbs with leds and went to get the coding changed so the car will stop throwing a hissy fit every time the lights come on. However, after we did this:
> Controller 09 - Central Electronics
-> 16 - Security Access - enter 31347
-> 10 - Adaptations
Change the 2 channels listed below
(1)-Leuchte25KZL HA59-Lasttyp 25  -  set to: 43 - allgemeine LED
STG09_Bordnetz_Anpassung_1-Leuchte25kzl-
(6) Leuchte25KZL HA59 - Dimmwert AB 25  -  set to 127
we still got the errors on the dash and the vcds said this:
                Address 09: Cent. Elect.       Labels: 5Q0-937-08X-HV1.clb
Control Module Part Number: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
  Component and/or Version: BCM PQ37BOSCH 028 0106
           Software Coding: 0F001A42C24722FB07A04082B10C07280000000000000000000000000000
            Work Shop Code: WSC 73430 790 00000
              ASAM Dataset: EV_BodyContrModul1UDSBosc 013004 (SK37)
                       ROD: EV_BCMBOSCH_013.rod
                      VCID: 79FC61F7F8B8018AFB-802C
1 Fault Found:
12307 - License Plate Light
          B12CA 01 [009] - Electrical Failure
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 44510 km
                    Date: 2016.10.21
                    Time: 17:59:25
Can anyone help please?
I had the same problem.
For some reason, the car is very picky about the license plate lights.
Don't worry, the warning message will disappear in a few hours.
If you don't want to wait, you can try the following:
1) CAR / SETUP / Factory Settings / Lights (in infotainment menu)
2) Use the 'Soft Reset' function in VCDS while coding
It's better to do the coding before you change the bulbs to LEDs, but again...the warning triangle will disappear sooner or later if the coding is correct. :)
Edited by aki78
I bought CANBUS error free LED's and they still throw up an alarm, going to change them back, i can't be bothered with all this coding lark just for a different colour light.
  • 4 weeks later...
I meant to post back, the error did indeed clear when i got in the car the next day.  How very odd!  But glad it is all sorted.
Stanian, as I found out it makes no difference if you get error free ones as the car knows they are leds regardless.  To be fair it was very simple to code using the post above and remembering the error won't go away for 24 hours ish.
