Seat belt
One of the two seat belt buckles bolted to rear middle seat is damaged. Any help welcome as to removing plastic panel so as to access bolt.
If you fold the seat forward and lift it up (as you'd do to remove the seat) , you'll see 2 torx screws at the back of the plastic trim .
It will still be held captive by other trim above it.
It's a good start though, I'll have to have another look later  ;)
Taken trim off that's attached by 4 torx screws, but can't get trim off that's hiding bolt head to undo buckle.
2014 Outdoor 1.2 DSG (14 Reg)
Unclip trim opposite two torx screw holes. Then push trim to access bolt head
