Mercedes Alloys
Im thinking of getting a set of mercedes4e_2.JPG alloys and just want to check they will fit the Octavia 2.
(fitting 205 x 55 x 16s to the rims)
Rim Width:
7.5J
Stud Diameter:
112
Offset:
35
The stud diameter is correct, and IIRC so is the offset, so I don't see why they wouldn't fit. Those rims look hot with low-profile tyres.
PCD is correct however offset could be an issue.
Octy 2 offset is usually around ET45+ on alloy wheels. Have tried Superb alloys on one and they stick out a mile (ET35).
Also, check the centre bore, VAG cars run a 57.1mm centre bore if I remember correctly, and Merc is different, so you'd need a spigot ring, as you never mount a wheel with the weight on the bolts!
