1.4 16v CGGB engine using coolant
Hi all.
My wifes 1.4 16v CGGB engine has used a bit of coolant, it's a cm below the MIN mark.
Oil is clean no mayo under the cap and the car runs fine no overheating.
I'm going to top up with G13 to the Max and keep an eye on it.
Is it a problem with these engines?
I'd check the radiator switch attached to the raditor, they are common for leaking.
