Steering is suddenly heavy, especially when braking!
Two days ago whilst pulling in to a parking bay, i noticed the steering go really heavy and kind of judder! I was a bit 'shocked', but you know, passed it off, lol
This is my wife car, so asked her if she'd felt anything, a dumb look came my way...
Anyway, i've driven it a few more times now (whilst my T4 is off the road) and noticed this happen on different occasions...
When changing direction, there's a real resistance to the steering.
When braking it nearly becomes impossible to steer! Almost crashed this morning, as i braked, went to steer and pretty much couldn't!
When you pull up, if your'e turning and braking, you feel a judder (kind of like ABS), and it's really heavy to turn.
There's no problem with the steering centring...
I thought maybe the fluid was low, not checked it since we bought the car, 6 months ago! Couldn't see a reservoir in the bay....
Ideas and thought welcome.
Steering fluid low ? Brake fluid low ? Faulty pump or a leak in the system ? Belt tight ? All things to check
  • Sponsor
Check battery voltage before and after starting engine.
As Wino says, possibly battery voltage. The reservoir is sat under the battery, which you have to remove for access. I had a similar problem of heavy steering when turning through a down hill left hand bend, but this was down to low PS fluid level.
Cheers All.
I'll have a ganders tomorrow.
Don't stop the suggestions though, if anyone else has any other thoughts.
