Radiator fan stays on
Hi all
My rad fan starts up just after I start car and won't stop. It runs for about 10 seconds after I turn engine off. Bit annoying. Can anyone tell me what it could be. Any help much appreciated.
Many thanks
Andy
Have you got the air conditioning on?
No it as climate control which is off.
I'm having similar problems with my 1.2 diesel Greenline fabia
I've got z faulty egr valve at the moment and the garage said when its replaced it will be ok
Picked my fault egr valve on a diagnostics machine
I'll try a bit of WD on cables first if it doesn't help not sure. Don't want an expensive repair on a 2006 ref. Although it is in great Nick.
had the same problem with mine,it was also going slightly over halfway on the temperature gauge when driving,new thermostat sorted mine out
