Rough Idle when Cold
Hello everyone,
When i start the car when cold, engine runs rough at idle...
When warms up runs smoothly.
Any ideas ?
Coolant temp sensor would be my first suspect.
Thank you for your prompt reply,
Do you, by any chance, know the part number to look for in order to buy a new one to test it ?
06A 919 501 A coolant temperature sender
cooler for coolant 2 pin
black
20MM 1 AVU,BFQ
Guys, problem still occurs...
You resolve this?
Im having same problem,only on cold start first thing morning and only lasts bout one minute as if when the sai cuts out or auto choke it settles back
Occasionally when driving but jumpy
You scan for codes?
You resolve this?
You scan for codes?
Given you have a vRS and not a 1.6 I'd suspect you should think about a SAI pumpectomy.
ordered the combi plate
