Rear Wheel Bearing Tools?
I m trying for find what tools I need to change my rear wheel bearings, mostly what size 12 point socket do I need? And is there a special nut for the caliper housing too?
TIA
Phil
Sorry should have mentioned I have a VRS Estate
Drum:
Disc:
(B5 Passat, but I expect broadly similar)
Gaz
TIA
Phil
Hi Phil
The rear hub nut is a 30mm 12 sided socket, you will need a 15mm and 13mm spanners for the calliper bolts (no need to remove carrier), a small chissle and hammer to remove hub nut cap, a three leg puller is advisable to remove the hub, but you could get away with hammering it off. Hope that helps?
Paul
