FL side repeater replacement
Done a search but can't find anything on how to replace the side repeaters in the FL VRS mirrors.
Any guides, links, tips appreciated.
Need to replace the indicator unit as it only has 1 working LED in it.
Thanks in advance
Mirror glass out, motor out, then remove the light unit with the little torx screws. Unplug, and replace in reverse.
Mike
Nice one.
Mirror glass just prizes out??
Mike, the motor doesn't need to come out on the FL.
It's a case of mirror out, remove some screws, cover off, remove some screws, base plate off, remove some screws, indicator unit out :)
The mirror just pulls out, if you move it to one side it'll make it easier to get your fingers behind it.
Much like this:
Much like this:
Thanks, video will help a lot.
