Vrs 4x4
have someone tryid to modify oktavia vrs 2007 sedan to 4x4 ?
  • Administrators
Hi,
Probably. It was often talked about on the previous generation mkI. It's perfectly possible, almost anything is with the budget!
I've also moved this to the mk II forum.
Possible? Yes. Worth it? No. If you really want a performance Skoda with AWD, its easier to get a 4x4 one and tune it or transplant the engine into that than the other way around.
There's also a V6 octy 4x4.
This fella in Russia's done it with rull 2.5 TFSI Quattro running gear from an RS3/TTRS!
https://www.drive2.ru/r/skoda/809738/
I previously owned an RS3 myself, this Octavia must be awesome!
(P.S, on the link above, right click on the page and select "translate to english" and you will see all his posts on that forum relating to the conversion)
Edited by Muzza80
