Replacing the Coolant Temperature Sensore on a TSI engine?
Is there a guide to doing the above on here, search hasnt found anything?
Where is the sensor located on a 2010 VRS, TSI engine?
Mine runs very lumpy when the engine is cold and I believe it could be the CTS which I understand is a fairly cheap/easy replacement. Failing that the coil packs will be changed....
Thanks,
AFAIR it is under the inlet manifold and a bit of a (or even a big) pig to access. Edit: several hours work at a guess. maybe 3 or more...depending on whether your take IM off or not.  I haven't come across a guide specifically. This one shows a water pump replacement and in some of the photos you will see the CTS referenced.
http://www.golfmk6.com/forums/showthread.php?t=75491
Edited by TheClient
Thanks very much.
......garage it is then.
